I recently purchased a new PC with a few weird installation. I had complain to the seller that they had sent me the wrong PC, so I had to return it to get a new one sent out.
I now think they deliberately install my PC with mistakes and now must fix them.
Firstly they removed the original Corsair Fan from the H45 liquid cooling with a regular RGB fan that was suppose to come with the case. I asked them why they did not install the RGB fan else where and had to take off the original H45 liquid cooling fan with a RGB. Their response was they would send me out a Corsair fan which is not the original.
Secondly, I realised that the installation of the Corsair H45 fan might be wrong. The 3 pin connector for the pump is actually connected in the CPU Header, and the RGB Fan which is connected to the H45, the 4 pin connector is connected elsewhere. I am unsure if this configuration is okay or not. But it has gotten me worried. As the motherboard I have, the Asus Prime Z370-P II, has a AIO Pump header right under the CPU Header. So I am unsure why the Pump was not connected to the AIO Pump Header and the Fan in the CPU Header.
LAstly, my PC has only 1x 16GB Ram, as I know my motherboard, the Asus Z370-P II is dual control memory, I don't understand why 2x 8GB Ram was not installed.
It would amazing if I could get some advice to how to fix these problems. I am unsure if these are mistakes or not, and if so, maybe they were done intentionally.
My PC is working fine but I worry if problems will occur in future with these weird installation.
