Dear website I have a 4yo Asus ROG20AJ PC, that Asus made two weird laptop power supply for this desktop pc, one for the motherboard(180W), one for the GPU(230w). I decided to upgrade the GPU then found out the GPU power supply is faulty, therefore now I've bought a new EVGA 600W bronze psu that came with a tester (basically a wire that connects the green and black cable of the 24 pin, should be the same as the paperclip PSU testing method).
The thing is that the motherboard on this PC is also unique that it doesn't use a 24 pin connector for power. So now I continue to use 180W for motherboard and 600W for GPU.
In the end, to power my GPU, I must connect the tester on to the 24pin motherboard cable of the PSU so that it can deliver power to the GPU. (Without the tester, the psu remains off cuz its not connected to a motherboard, and only connected to a gpu).
I'd love to know if this could be a long term solution. What kind of effects could a wire, instead of a motherboard, have on a PSU? Will it damage the new PSU? Will it deliver the same power as if I could set it up regularly? I couldn't find any info as unique as this on the internet so I decided to ask the best tech website available. Really hope the English is readable, and any information is appreciated!
