My 1080 ti underperforming, please help!
Jul 16, 2018
29
Ok english is not my first language just saying..
So i got the asus strix oc gtx 1080ti a week ago and it is under performing and doing worse than my old 980ti. Anyone know what could be the problem? On cs and fortnite im gettin 120fps avg which is really bad when i have a 144hz monitor. Im playing on 1920x1080. (Please dont tell me that 1080ti is overkill) And on world of tanks im gettin 90-100 fps avg when my friend with a 1080 is getting 200fps avg. I dont have vsync on, all my nvidia 3d settings are correct. (Looked on internet for the right settings) So i dont really know what to do anymore..
Specs:
i7 6700k 4.0GHz
Gtx 1080ti (with newest driver: 398.36)
32GB RAM
Games running on SSD
RAM speeds are correct.
I got a 850W psu which is overkill i know..
Cpu and gpu both under 50celsius all the time
Well i reinstalled windows so im pretty sure that already uninstalled the old ones right?
Maybe. It's *possible* that Windows tried to install some drivers itself for the card. That happened to me with a fresh install of Windows with an AMD card once.
Well i did clean the drivers and get the new ones.. Didnt help.
Something is wrong with your RAM. It is performing in the 1st percentile and clocked at 1600mhz. That is very slow for DDR4 RAM. I would start by resetting your bios to factory defaults as you may have underclocked your RAM by accident.
OK it made the fps ALOOT better.. Thank you so much, but is there still something i could do im still a bit dissapointed at the results. (Almost same fps on 980ti) And i think it should be alot more powerful than my old one
Ok im back home again. Games running really slowly still.. I think its still the ram but i dont know how to fix it. Resetting bios didnt help alot.
MERGED QUESTION
Question from wotepicvideos : "1080 ti underperforming"
And this is why you stick to one. These have all been asked and answered. Your just wasting peoples time.
1333 mhz which is really weird bcs resetting bios doesnt help and on bios it says 2133mhz.. I think my pc is messed up somehow.. Sometimes its underclocking the cpu to 2 cores and weird stuff like that.. ? :/
I have reset it by removing the coin but it didnt help. Ive reinstalled windows and drivers
