Hi there Aimhigh1,
As you've tried to format it, I assume that you've got no data over there. Am I right?
Apart from that, except for trying to test the drive with the brand specific tool as Shaun o suggested, you can see if the drive is under warranty. In case it is, you can contact the place you got it from or the manufacturer's Support and eventually RMA it.
Cheers,
D_Know_WD
