My 2nd GPU isnt detected in Nvidia control panel, help?
theradicator
74
Hi, i had 2x gtx 970, they were working perfectly, but then i downloaded the newest drivers. Suddenly when i check in nvidia control panel it dosent get detected help?
btw, i have a asus x99 deluxe as mobo. If anyone has a solution, then i would be grateful if you said them. thanks in advance 😀
Okay, then on to step 2:
Every time you update your drivers you have to re-enable sli. It is disabled by default. but to do this, it needs to recognize that you have two cards....
