Question My 9800x3d has very high temps and i have no idea why
Vetrix1996
Commendable
Nov 4, 2022
66
60-70c idle and in game its 95c......this cannot be how it was intended. This is out of the box temps on a TUF GAMING X870-PLUS WIFI with latest bios.....is there a hidden setting in bios doing this? Did i install the AIO and the case fans correctly? (wont fit at the top so need to do front mount). What do you think? Cooler is Liquid Freezer ii 360 AIO, loud as a result of the temps, definitely louder than my old NHD15.
UPDATE: ITS FIXED, I FORGOT TO TAKE THE STICKER OFF THE PLATE LMAO
How many watts do you consume when it reaches this temperature?
CPU package power 85w when i open a game and it hits 95c
I see a lot of dust inside, first try putting the ceiling fans in to blow the air out of the box.
If you don't have any improvements, the only thing I can think of that might have a problem is the Arctic.
I don't know when you applied thermal paste and what kind it was, but it's a good idea to take the pump out and look at them again, as well as the motherboard pins.
It was just made today so everything is 100% fresh. So these temps are not normal for the 9800x3d no?
Unplug all power cords and cables when you do anything.
Loosen the screws carefully, check (I hope you removed the jelly from the pump) and screw in crosswise and not with force until the screws are tight.
Thank you for the advice, i will try it and see if it works any better. By the way what do you mean by "jelly"?
