My a10 9700 is running very slow. What is the problem?
Jun 22, 2018
6
My APU should have a good performance, like in this video: https://www.youtube.com/watch?v=IMf8XMrs4lA
But I'm not able to play outlast, even at minimum settings, it laggys a lot. In the video, the guy ruuned fortnite at a good settings and it ruuned without lag, but here, even with all in the low it laggys.
My computer is:
a10 -9700
8GB 2400Mhz ddr4 ram + 4gb 2400mhz ddr4 ram
550w evga bronze power supply
Windows 10 64bits in dual boot with solus os
motherboard a320m msi grenade am4
HDD WD SATA 3,5 1TB
SSD kingston 120GB (but i'm not using this)
So, whats is the problem with my computer? In linux, seems to be running normal, because the amd drivers there are bad, but in windows it should have a better performance.
Should I set the BIOS to 1GB for the graphic card of the APU? Or should I try it in auto mode?
Please, can anyone help me?
I just solved it.
If you have the same problem, just go to your bios and change the "advanced graphics" configuration from PEG TO IGD (because peg is pci express and igd it's the integrated)
I just solved it.
