Question My cat6a cable is stuck at 1000mbps
Hopsfy
33
I just replaced my cat 5e cable with a cat6a cable. I am paying for 3gbps down but my windows wont set my link speed higher than 1000mbps. I tried a second cable and same results. I restarted my PC and the Router/Modem combo and nothing is changing. I also do not see any driver updates on device manager. Did I do something wrong?
What network hardware do you have? Without specific network hardware that supports 10GE you will get 1GE. Changing the cable is the least significant hardware.
If you're using integrated ethernet controller, then what model motherboard do you have?
If you're using discrete ethernet controller, then what is model name of it?
Ethernet controller has to support speeds higher than 1gbit.
Anyway - we have already concluded, your modem/router doesn't support speeds higher than 1gbit.
So modem/router has to be changed and probably also a new ethernet card is necessary.
