Question My CPU get heats and the Cooler fan as well
Aug 14, 2022
7
I have made this PC from a PC dealer who is best at the business of custom PC development.
The PC specifications are .
SMPS : Corsair VS600
CPU : Ryzen 7 5800x
GPU :Zotac GeForce GTX 1660 Super 6GB
Cabinet : Ant ESports Cabinet ICE 211tg
SSD : Crucial 500GB M.2 Nvme
Cooler fan on CPU : Cooler Master Hyper H410R Cooler
Mother Board : MSI B550m Pro-Dash
RAM : Corsair Vengance 16GB ( 8GB + 8GB ) 3200
It's going 91 degree on CPU Cinebench Benchmark App on multicore. And while playing GTA 5 on medium graphics, it's going to 87-88 , with that, cabinet gets superheat on the glass side.
On regular usage, like opening 4-5 tabs in chrome, and using notepad application, it stays at 60degree
It has enough airflow and the PC bought on 2nd July.
Please help how I can get it better.
Note : All the tempratures mentioned above are of Celcius degree.
Can you show a photo of your system with side panel removed?
(upload to imgur.com and post link)
How many fans installed?
What is ambient room temperature? Like 40C ?
This would indicate insufficient air flow.
This is a look-alike of Antec's NX310.
Well, we've seen worse front panel designs...
Ryzen 5800X
OK, now this is completely inadequate. This shouldn't be used on higher than Ryzen 5...
It's physics. Gpu exhausts its waste heat out the side. Glass is an insulator of heat; the heated air that doesn't flow up or down gets absorbed by the glass panel.
https://www.amazon.in/Ant-Esports-ICE-211TG-Transparent-Preinstalled/dp/B08FDS5N63
Fans : 2 in cabinet, one cooler, and 2 GPU.
Room Temprature : 30-32C.
Antec's NX310.
Yeah, kind of same design and model.
If possible, please suggest a better cooler then.
Enough place for airflow so not sure why it gets superheated. I can understand regarding the glass, but not sure how I can proceed for future with this heat.
I don't know what's available to you. Provide a store link, or your country(so I could look on partpicker).
SkyNetRising kinda told you: air not moving fast enough.
How many fans are in there and where are they?
https://ibb.co/8KMhrbc
Cpu cooler orientation wrong.
Reorient it this way
When the CPU was made, the cooler fan were at down side, when I took PC for heat issue, they just shifted to top side and said that this will work.
Great. So originally it was bottom-top orientation. That is passable for some cases, but not for this one. Switching that 180 deg and saying it will work was "brilliant". Top-bottom airflow never works. Never. Your "PC dealer who is best at the business of custom PC development" is below-the-worst on my scale.
