[SOLVED] My cpu has been running extremely high temps recently.
Nov 7, 2020
So I have an i9-9900ks and recently ever since I moved some cables for cable management, the cpu has been running extremely hot on games (80-90 degrees celsius) that I was previously able to run fine at 60-74 degrees. What should I do?
check your CPU cooler ASAP. you either unplugged the fan or knocked the cooler loose would be my guess. either way that is not normal and it should be addressed immediately.
