I have an Intel core i7 2600 @3.4GHz, I first found out that i had lost the cores (non-operational) when I went to play Minecraft, I went on task manager to set its Processes Affinity up to 2 cores, but when i tried to do it, there were only two cores left, 1 physical 2 hyper-thread, in the list, so I went to the performance tab and realised that the were only 2 core graphs where there is supposed to be 8. I then went on CPU-ID and it said that I had 1 Core and 2 Hyper-threads, it usually says I have 4 cores and 8 hyper-threads, so I instantly knew there was something wrong. Could someone please explain to me why this has happened and is this permanent or just temporary. I haven't been able to restart yet because I am doing important work which I am under a tight schedule with.
Specs:
CPU: Intel Core i7-2600 @3.4GHz
GFX: GigaByte GTX660 OC
RAM: 8GB @ 678MHz
Motherboard: Dell Y2MRG (OY2MRG)
Thanks for Reading.
Specs:
RAM: 8GB @ 678MHz
Thanks for Reading.
