[SOLVED] My CPU is way too hot, but I dont feel any heat
Jan 4, 2019
18
Hello Guys !
I have a problem with my CPU, but i dont know if its an actual problem.
I have an ASUS ROG GL753VE. When i turn it on, the CPU insantly gets to 50 C. When im using google, as i do right now it is like 50-70 C and its changing constantly. When im gaming, it it about 80-85 C. But I dont feel any heat coming out. I can boost my FANS, they are working perfectly, but there is not such a heat like 80-90C. Are my sensors bad, or should i change paste?
My CPU : Intel(R) Core(TM) i7-7700HQ CPU @ 2.80Ghz
wow this means cooling in this laptop is not enough do you play games on it try to play them at lower settings and check temp also i would made sure cpu cooler is working .
Yes, i've just installed a new SSD and another 8Gigs of RAM and i used compressed air to clean it. But even before the RAM and the SSD the system wrote that the cpu is hot.
I dont think so, my fans are working perfectly on 5-6k rpm. The air comes out so fckin fast. Tomorrow im going to apply the thermo paste cuz it arrived
