I have recently decided to build my own PC for entry to mid-level gaming. I have gotten a lot of help from other forums here while deciding what I want. I would like opinions on the build and on the upgrade parts I have listed, along with suggestions as how I could make it better. Thanks!
I started with a Newegg PC Combo: http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1750776
Will it all work together?
Also, I would like to upgrade the performance. To do so I am considering switching the motherboard, graphics card, and CPU with the following:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131980
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117302
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202049
Will it all work together if I do? What would be a better swap if not, or what would I need to make it work together?
I would prefer to not spend more than $800. not including the price of the tower, which I have already ordered.
If it helps, I mainly play Star Trek Online, Sim City 4, and The Sims 3. However, I am considering downloading games such as Skyrim once I have this.
Any suggestions/advice/help would be greatly appreciated. Thanks!
