my first build need help
imalwaysasking
Commendable
Nov 9, 2016
5
hi guys, im planing to build budget pc, and this is also my first build so i need your opinion about it and maybe there is any compatible issue
cpu : i3 6100 3.7ghz
motherboard : GIGABYTE H110M-DS2 DDR4
gpu : Inno3d Gtx 1050ti
ram : 8gb G.skill Aegis 1 stick ( maybe ill update to 16gb later)
hdd : 1tb seagate
psu : super flower 450W 80+ bronze (is this good psu ? i read sf make good psu but i dont really know it ,450w is enough to power this system ?)
Thank you
450W PSU is enough for your system. Super Flower is good, though i personally prefer Seasonic.
Your HDD isn't the best one. Out of 4 big HDD makers: Seagate, Western Digital, Toshiba and HGST (Hitachi); Seagate drives have the highest failure rate. For most reliable one, go with HGST drive. If you're on budget, a common WD Caviar Blue 1TB (WD10EZEX) will do just fine.
For RAM, always use 2 sticks to run it in dual channel. 2 sticks in dual channel is much faster than 1 stick in single channel.
comparison, 1x 8GB vs 2x 4GB: http://ram.userbenchmark.com/Compare/HyperX-Fury-DDR4-2133-C14-1x8GB-vs-HyperX-Fury-DDR4-2133-C14-2x4GB/3555vs3554
