My first build, questions.
ChaoticR
Commendable
Jul 23, 2016
This is my first time building a PC, unfortunately i will wait until the end of this year because i'm still saving some bucks to complete it, but i'm already making the parts list. At the moment my parts list is:
CPU: I5 6600K
GPU: Galax GTX 970 Gamer 4GB OC DDR5 97NPHH6DT8RVZ
Cooler: CoolerMaster Hyper 212 EVO RR-212E-20PK-R2
Motherboard: GA-Z170M-D3H
RAM: Kingston HyperX FURY 8GB 2133Mhz DDR4
PSU: Corsair CX-500W CP-9020047-WW 80 Plus Bronze
HDD: Seagate HDD 1TB 7200RPM 64MB Cache Sata 6Gb/s ST1000DM003
Case: Cougar Micro ATX USB 3.0 Black no PSU MX200
My questions are: Is everything compatible? Will GTA V perform well in this build? Are there any changes that could be made without making it too expensive?
Yes, that will perform very well for games like GTA V in 1080p. But just note that if you are not buying until the end of the year you will likely end up with a different GPU like a GTX 1060.
Also, I would personally opt to spend less on the overclocked CPU setup in order to afford 16gb of memory and a SSD. A locked i5 6500 on a H170 motherboard with the stock cooler will perform close enough to a lightly overclocked 6600k to warrant the downgrade in favor of the benefits of 16gb and an SSD.
I saw that the I5 6500 comes with a Cooler, should i get a cooler anyways?
Avoid the Corsair CX, CXM, GS line of Psu's. They aren't exactly crap, but with the money you are putting into the system you'd be much better served spending more and getting a higher quality component. Xfx, Antec, other Corsair lines, SeaSonic and most eVga Psu's would be a better option.
Also, ditch the Seagate drive and get a WD Blue instead. The Seagates have a much higher incident of failure than the WD Blue's, and the cost difference is just a couple of dollars.
I agree and would also add an SSD if you can, and definitely upgrade to 16gb's of Ram. Ram pricing right now is super cheap, double up now.
A ATX EVGA 600W 80 Plus Bronze - 100-B1-0600-KR works better? Just one more thing, i have a external Seagate HDD 1TB, is there any way it can use it as internal, maybe convert it or something? About cables, what do i need to buy? As a first timer, is it better to build it myself or pay someone to do so?
The 600B is a slight improvement, I use one in my current machine. However if you can afford it I would look to step up to the XFX TS series or even the EVGA G2 series, both of which are priced very competitively in the 550w range.
As far as converting the external HDD to internal, it can be done with certain models, but not all. Also consider some external HDDs may only be 5400 RPM, not very good for load times in games. And of course, there are always risks with taking things apart and trying to repurpose them.
