My First Build!
CPU - If you can stretch the budget $25, then look toward the i5-6500
MB - Look toward the B150 chipset with four memory slots. Leave an upgrade option open..
MEM - Same specs on the Crucial modules below for less cost.
SSD - 120GB is pretty small and will fill up quickly.
GPU - Stick with the integrated HD 530 for now and add a GPU down the road when you can. The GTX 1060 would be a good match, or maybe the RX 460 / RX 470.
CASE - On a budget, I like the Deepcool lineup. The one below comes with two fans
PSU - No. XFX, Seasonic, the EVGA G2 lineup, or filter through the Tier 1 or Tier 2 list. www.tomshardware.com/forum/id-2547993/psu-tier-list.html
CPU:...
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($66.98 @ Newegg)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory ($35.98 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive ($68.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.71 @ OutletPC)
Case: Deepcool TESSERACT SW ATX Mid Tower Case ($39.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply ($68.99 @ SuperBiiz)
Total: $437.63
