Ok, maybe this is close to what would be a good system for under $1000 -- and this includes WinXP Home OS ($90 bucks).
Total w/o S/H -- $945.10
So, is this a pretty good system using the AMD CPU?
For AMD, I don't know too much about them so the rest of the system I feel fairly comfortable with except video card and I would buy a better video card (and maybe Powercooler Radeon isn't that good but probably good enough unless there's some other out there better for close to same money) if this system was for me but it's not ... friend and relative.
Comments??
This help you schafer1986??
THX. -OT
--- ALL PRICED OUT FROM NEWEGG.COM --
ANTEC ALUMINUM SERIES SUPER LAN BOY MINI TOWER CASE
with Clear Side Acrylic Window and
FREE Case Carrying Strap - Retail
N82E16811129145 $77.50
Antec 430W Power Supply, "TRUE430" -RETAIL
N82E16817103908 $71.50
GIGABYTE "GA-K8NS PRO" nForce3 250 Chipset
Motherboard for AMD Socket 754 CPU -RETAIL
N82E16813128241 $94.00
AMD Athlon 64 2800+, 512KB L2 Cache,
64-bit Processor - Retail
Packaging: Retail(Heatsink and Fan included)
N82E16819103452 $130.00
Crucial 184 Pin 512MB DDR PC-3200 8T - OEM
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
N82E16820146541
2 @ $87.00 $174.00
POWERCOLOR ATI RADEON 9600PRO Video Card, 128MB DDR,
128-bit, DVI/TV-Out, 8X AGP, "R96A-C3N" -RETAIL
N82E16814131219 $118.00
Hitachi 160GB 7200RPM SATA Hard Drive,
Model HDS722516VLSA80 Part# 13G0254, OEM Drive Only
N82E16822145051 $89.88
SONY Black 52x32x52 Internal IDE CD-RW Drive
W/ CD Maker Software, CRX230ED-B2, OEM
N82E16827106823 $27.99
One Day Sale, Ends 12/28/2004 5:30 PM PST
NEC 16X Double Layer DVD±RW Drive, Black,
Model ND-3500A BK, OEM
N82E16827152032 $62.99
Samsung Black 1.44MB 3.5inch Floppy Disk Drive,
Model SFD321B/LBL1, OEM Drive Only
N82E16821103203 $6.99
Microsoft Windows XP HOME Edition
With Service Pack 2 -OEM
N82E16837102151 $92.25
EDITED ...
-- I wanted to add that if going to an INTEL based MOBO & CPU then something like this would/could increase the costs just a bit --
Like going with ...
IS7 mobo -- $90 ($4 diff lower than AMD based)
INTEL P4 -- $188 ($58 diff HIGHER than AMD based)
BUT, if going to a "higher" clocked cpu, you're looking at quite a bit more:
Intel Pentium 4 3.40E GHz 800MHz FSB, 1MB L2 Cache
w/ Hyper Threading Technology - Retail @ $307.00
-- right around $170 BUCKS higher than the AMD cpu and $130 higher on the Intel CPU.
Also -- I didn't put a SOUND CARD in there on the original system -- both these boards have them ONBOARD so that might be fine. Otherwise, figure about $70 bucks or so to add one in there... (like for an Audigy2).
HTH.<P ID="edit"><FONT SIZE=-1><EM>Edited by okietex on 12/28/04 02:41 PM.</EM></FONT></P>
