My first pc build from scratch needs some expert opinions
zvinca.andrei
Commendable
Jan 27, 2018
15
Hi there,
I'm working on gathering all the components for my new gaming pc and i've already got a case and psu on the way.
Here's a list of everything else that's going in my new PC :https://pcpartpicker.com/list/WWvv8K
Keep in mind that the GPU is not a new purchase, i'm using my old 970 until prices drop a bit, the power supply is a 650 gold rating model but it's not one from the list provided by pcpartpicker because it's something produced in my country. The PC case is also made here so the manufacturer is not on partpicker's list but it has very positive reviews.
My issue is, will the 650 80+ gold rating psu be enough for those components on my list + 5 case fans (120mm, probably cheap ones) that come with the case. I'm planing on using all 5 of them and that's one of the reasons i went with the b350 gaming plus mobo, 5 case fan connectors, that and the fact i like the idea of pairing my msi gpu with msi mobo.
In theory i know i should have enough power but what happens if i decide that i want to give overclocking a try for the first time. not much, maybe 20-30% on the cpu, give it a bit of a boost, or if i want to use the cooler boost from the msi gaming app.
If overclocking comes up at some point, would a 650 gold rating power supply still be enough for cpu gpu and 5 case fans, or will the psu just burn up in flames? Or maybe it's not enough even for turbo clocking ... i just don't know how pcpartpicker calculates the wattage if it's for stock speeds or if they take into account turbo modes, oc and all that other stuff.
If you're wondering why i'm trying to make this as budget as possible or if you think a 10$ upgrade on one component would be better think of this. Parts over here are at a minimum 25% more expensive than in the US. The SSD is almost 60% more expensive. You get the idea.
Thanks in advance!
Did some high level digging and found one local Romanian guy who did the video unboxing of Njoy Woden 650W,
link: http://hmongdownloadyoutube.com/video/3OK93YFKk48
I don't know about you guys, but for me, that PSU looks too empty in the inside. Also, the marketing of that unit looks too good to be true (e.g 700W peak power for 60 seconds). And when it looks to good to be true, it usually isn't true.
About wattage.
GTX 970 is 145W GPU, add the rest of the system to it at about 200W and most what you're looking for is 345W. Even if you OC your CPU/GPU, max what your PC (with 5x fans) would consume is about 400W. So, 500W PSU is more than enough for your PC.
As far as pricing goes, Njoy Woden 650W costs 234.99 RON,
source...
see, that right there is why i sometimes hate looking at youtube reviews and builds. Sometimes it's hard to tell when someone is using something just because of aesthetics. They all say "this is very good" but they rarely give alternatives or explanations as to what makes that part so special. Of course, i'm only referring to the little things such as coolers, fans, radiators, but for me those things count too. :)
