My first pc build, help!
Fr0stbitekill
Commendable
May 16, 2016
4
So im brand new to pc and pc gaming and parts and since i play on gettimg a custom pc i gathered the parts i wanted but i dont know if the compatibility checks out or if its even worth my money. Any help will be appreciated thanks! My current budget is $1300 but will go as high as $1450. Parts i chose are as follows. Any suggestions as what to replace or what to add will also help
Processor:
Intel Core i7-6700K Skylake Quad-Core 4.0 GHz LGA 1151 CPU
Motherboard:
ASUS ROG MAXIMUS VIII HERO LGA 1151 Intel Z170 ATX MOBO
Video card: GIGABYTE GeForce GTX 970 4gb WINDFORCE 3X video card
Storage: Seagate Desktop HDD ST3000DM001 3TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Memory: .SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DIMM DDR-2400
Optical drive: asus DRW-24B1ST/BLK/B/AS DVD/ CD Writer
Case: Phanteks Enthoo pro ATX Full tower case
Power supply: EVGA 500W 80+ BRONZE CERTIFIED ATX POWER SUPPLY
Case fan: needed?
CPU cooler: ARCTIC freezer 7 pro Rev. 2 45.0 CFM fluid dynamic bearing CPU cooler
The PSU is poor quality - I'd get an XFX TS 550W. A good PSU is important especially for a system in that price range. Do you really need 3TB of storage? Just curious.
You are overspending on the motherboard and CPU. Get a cheaper Z170 motherboard, get an I5-6600K instead of the I7, and then put the money into a better GPU, like the upcoming GTX 1970 (released in like 10 days) or the upcoming GTX 1080 (coming out in less than a month).
I would hold off for a few more weeks regardless of the pain it may cause you. Nvidia is about to release their new cards and they are substantially faster than the current gen. Even if you are not interested in them you should still wait because it will drop the price of everything beneath them.
By then Kabylake CPUs will be out, and so much stuff will be different; it's pointless to design this far in advanced.
