My first pc gaming build and need help to finalise it!!!
Jazalinco
14
Hey guys this is my first build and what to make sure its going to be good for gaming, im looking to spend around $1500 on it. if you think i should modify any of the parts please let me know. also i have no idea on what monitor, keyboard or mouse to get so please give me some suggestions, This is what my build consists of so far:
CPU: Intel Core i5-4670K Quad-Core Processor Socket LGA1150, 3.4Ghz, 6MB L3 Cache, 22nm (Retail Boxed) Gen4 (BX80646I54670K)
Motherboard: Asrock Z87 Extreme4 Socket 1150 Intel Z87 Chipset
CPU Cooler: Corsair Hydro Series H60 SE CPU Cooler
RAM: Kingston HyperX Genesis 8GB (2x4GB) DDR3 1600MHz
HDD: Seagate Barracuda SATA3 6.0Gb/s 1TB 64MB Cache
Power Supply: SeaSonic S12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
Case: Cooler Master HAF 912
Case Fan: Cooler Master 200mm Red LED Silent MegaFlow Case Fan
DVD Drive: ASUS Internal 24x DVD Writer
GPU: MSI GeForce GTX 770 Gaming Edition 2GB
SSD: 128GB Samsung 840 Pro
Monitor: ASUS VE248H 24in Widescreen LED Monitor
Mouse: Razer DeathAdder 2013 Gaming Mouse
Keyboard: Razer Blackwidow Ultimate 2013 Elite Mechanical Gaming Keyboard
Thanks for the help :)
I suggest you switch that RAM for Vengeance Pro 1866Mhz RAM. The PSU is weak, look into a HX650. As for the keyboard, there's much better than Razer out there. If you'll be doing FPS gaming and have no interest in a bunch of programmable keys on your keyboard, go for the Corsair K70, if you will use programmable keys, then Corsair K95. These two keyboards have the best mechanical switches, really made for fast paced action games. They have programmable individual backlighting, and for the price, they are simply great. It's funny because everything I mentioned here is from Corsair, but I'm not exactly a Corsair fanboy, just so happens that the things that needed improvement could be replaced by a better, Corsair product. The mouse is...
Ditch the motherboard and go for a GIGABYTE GA-Z87X-D3H about the same price getting much better bang for your buck with a Gigabyte especially when overclocking and all the other features it has.
Ditch the case and fans and go for Corsair air series fans and the Corsair 300R case or 400R if budget can be stretched.
Look at some Evga or Gigabyte branded cards i swear by Evga for their extended warranty but either of the 3 Msi/Giga/Evga will be fine.
I would also go with a Corsair modular 650/750TX or HX Power supply.
I suggest you switch that RAM for Vengeance Pro 1866Mhz RAM. The PSU is weak, look into a HX650. As for the keyboard, there's much better than Razer out there. If you'll be doing FPS gaming and have no interest in a bunch of programmable keys on your keyboard, go for the Corsair K70, if you will use programmable keys, then Corsair K95. These two keyboards have the best mechanical switches, really made for fast paced action games. They have programmable individual backlighting, and for the price, they are simply great. It's funny because everything I mentioned here is from Corsair, but I'm not exactly a Corsair fanboy, just so happens that the things that needed improvement could be replaced by a better, Corsair product. The mouse is great, I personally own the RAT 7, and I dig it, I've had over 12 mice in the past, and this is the first one I really am starting to like, since it's fully customizable, I can make it longer, shorter, heavier, higher, add a pinky rest, remove a pinky rest, program buttons, etc. If I'm doing casual gaming I'll change the back to the highthened palm rest, if I'm going for a marathon I'll switch over to the grippy, rubber palm rest, etc. And it looks so cool!
Thanks for the help guys much appreciated, if anyone else has any ideas please feel free to share, also trying to keep my build around $1500 and will be doing my shopping at www.pccasegear.com
Your rig is nice but there can be some improvements at the same price!
The SSD - why to go for 128 GB samsung 840 pro if you can get a ssd around 250GB and even better performance at same price. Go for samsung 840 evo ssds.
Latest posts
