My First time Building my Current PC
May 14, 2018
Hello , So soon i am planning to upgrade my current pc, my pc is pretty old , i am using this one since 2011, i never upgraded it , all i did was windows reinstall/update and thats at all, I will tell you my current PC parts and the parts which i am planning to buy to change them with the old ones , ofcourse everything it depends from the motherboard but we will get to that question as well.
So thats the PC which i am using at the moment.
Memory 2x slots of 2gb = 4gb , So i want to change that with 1slot of 8gb Memory 1333mhz, thats the biggest MHZ that my motherboard supports, I am planning to change the oldest slot of 2gb memory with the new one of 8gb and will keep the rest 2gb to get 10gbs in a total?
Graphic Card - my graphic card complete crap (it was good before few years) Right now i am using the AMD RADEON 5670HD 1gb, i want to change this one with the MSI 1050TI
Power Supply - i don't know which brand my current power supply is , i am just not interested in that at all , i just know it is somewhere between 300watt, I don't know which power supply will be the best for the 1050TI but i am planning to buy something of Segotep , fsp , corsair etc. somewhere around 500WATT - 600WATT with 80Plus bronze
And my current processor is AMD Anthol 2 X3 450 3.2ghz i am planning to change it with AMD RYZEN , AMD Ryzen 3 2200G are the AMD Ryzen 5 1600X, So My biggest question is my motherboard going to be able to support one of this processors, My Motherboard is this - MCP61M-M3 , you can google it and you can read the specifications, It does says that it can run AMD processors, but is not defined exactly
So that was my question and those are the pc parts which i am planning to buy for an upgrade, They are not the greatest but i want it to be more economical thats why
So please answer me it is good , Can i support them, If not will be sorry alot, because will need to change even the motherboard and will be unpointless, because it will better to buy a new PC.
Mixing oddball memory combinations carry no guarantee from memory manufacturers to work together. You are free to do your own compatibility testing.
AMD RYZEN , AMD Ryzen 3 2200G are the AMD Ryzen 5 1600X do not use DDR3 memory so your plan on memory is a non-starter.
You asked, "So My biggest question is my motherboard going to be able to support one of this processors". The answer is no.
MCP61M-M3
http://www.ecs.com.tw/ECSWebSite/Product/Product_SPEC.aspx?DetailID=1139&CategoryID=1&DetailName=Feature&MenuID=24&LanID=0
◦Supports AMD AM3 socket for AMD Phenom II processors
MCP61M-M3
