So my friend asked for my help, he said his CPU led on his motherboard is lit. He tried to troubleshoot it from yt but his PSU doesn't have on and off switch.
He said its a generic psu and it says it has a peak watts of 750.What is his pc setup and what is the psu model with no power button?
He's not getting any video signal from the unit. It just runs with the cpu led on.Can he get to bios screen?
He said it happened to him before, the cpu led on the motherboard also went on, but he didnt get the blue screen of death and it eventually just fixed itself.Can he get to bios screen?
Ok will tell him and inform you the outcome. Thanks!Ok tell him to shut off computer/unplug it. Pull the nvidia gpu out. Restart and tell me what happens.
Wait do I tell him to remove the graphics card or just plug the monitor via the mobo or remove the graphics card then re-install and then plug the monitor to the mobo?Im sorry tell him to plug the monitor to the motherboard graphics port.
Alright. He said his pc is about 1 year and 2 months old he just recently started experiencing he in case you think its a new build.Lol sorry Im trying to see if the gpu is the problem and rule that out. So remove gpu, plug the monitor in to the motherboards graphics port, his cpu has integrated graphics, if the computer starts up without the gpu then that is probably the problem.
Ok he said he followed the instructions and the cpu led is still on. The gpu is removed, and the monitor is connected via the mobo.Lol sorry Im trying to see if the gpu is the problem and rule that out. So remove gpu, plug the monitor in to the motherboards graphics port, his cpu has integrated graphics, if the computer starts up without the gpu then that is probably the problem.
He said it was working before until he switched off the pc and connected the chassis fan via the system fan port then the unit started to act up.Lol sorry Im trying to see if the gpu is the problem and rule that out. So remove gpu, plug the monitor in to the motherboards graphics port, his cpu has integrated graphics, if the computer starts up without the gpu then that is probably the problem.
