Case: Thermaltake Level 10 GT
Mobo: Asus Z97-A
Headphones: Sennheiser HD 598 (not sure if this matters)
The rear audio jack works fine through the mobo. The HD audio setting is enabled within the BIOS. The HD cable header is connected to the appropriate slot on the mobo. I do receive sound out of the front panel audio jack, but I am receiving a static/buzzing in addition to the sound. For now I have switched to the rear audio panel of the mobo. The case is brand new, just installed everything last night. Is this a known issue? Can it be fixed or is it poor cable management by Thermaltake? (Front panel cables came pre-routed). Also, If a soundcard could solve this issue I would like to know.
Budget for Soundcard: Under $40 would be great. ( I am not an audiophile)
I would like a headphone amp on the Soundcard though.
Thanks,
JW
Mobo: Asus Z97-A
Thanks,
JW
