denis776 Reputable Apr 29, 2015 21 0 4,510 May 13, 2015 #1 Hello. I noticed that my SATA cable is blocking one of my gpu fans. Gpu has 2 fans. And my question is if its bad or critical?
A austinfett Reputable Feb 26, 2015 142 0 4,710 May 13, 2015 #2 The SATA cable is physically not allowing the fans to spin? Uh.. You should move that cable out of the way. You don't want your card over heating. Upvote 0 Downvote
M Mrcreballing Reputable May 12, 2015 27 0 4,530 May 13, 2015 #3 If everything worked OK until now, you shouldn't have a problem. Hold the cable so that it does not happen again. Upvote 0 Downvote
