My GPU fan spins but my monitor says "no dvi signal"
Shotingxtar
13
My monitor is fine, it works with the integrated graphics.
DVI: unknown ( but I doubt its the problem )
I tried using HDMI: still no signal (HDMI works)
so, I'm guessing my GPU is the problem ? yes ?
any tips or tests you guys might recommend ?
Good point, do you still have a warranty?
Shotingxtar
13
well shit that's very kind of you, I live in NYC. I guess amazon is the way. But like I said, I dont think the cable is the root of the problem. otherwise why wouldnt it work with my HDMI ?
nathanstrainrocks
445
Shotingxtar
13
Unfortunately, the PC is from dell. Over priced piece of junk....
Well, thanks for the help anyway. I will stick the integrated graphics until the time comes :) .
nathanstrainrocks
445
Sorry I was not much help.
