[SOLVED] My GPU is running below 40 % usage at a really low FPS.
Jan 31, 2020
I am running a GTX 1060 6gb with Ryzen 1500x. It started running GTA 5 at approximately 40 fps and it even drops to 30(sometimes) with restored graphics. Is that normal? I have a 700 w of power supply.
Can you please provide me with a solution?
Phaaze88
Ambassador
Well, you need to fix the single ram stick issue first. Some 10 or so years ago, single ram configs were fine... not anymore.
Dual channel, and at least 3000mhz frequency - Ryzen has some of it's performance 'gated' behind memory speed.
Jan 31, 2020
Cpu usage is 50 max and down and the temperature is 46. GPU temperature is max 70 and its usage is max 38 . I have 8 gb of 2666 mhz ram from which 7000 or little bit less is used during gaming. My ssd is 120 gb kingston and the Hard disk is 1 TB of seagate 7200 RPM
Phaaze88
Ambassador
