My Graphics card will not allow any signal to my monitor when installed either from the integrated graphics or the card it self. I tried uninstalling onboard graphics and re-installing the card, I tried running the OC guru disk drivers that came with the card then restarting with the card back in the machine but still no signal. I also bought a 500watt power supply to accommodate the card and made sure I was grounded before touching anything on my system, I'm trying to connect the two with a DVI cable and did resort to trying an HDMI cable, so I really am at a loss. My computer is some piece from Costco here.
"https://www.bing.com/images/search?q=hp+pavilion+A8+vision+AMD&view=detailv2&&id=27253F3E9A691579050B93F5690CE8E63CA2D1E6&selectedIndex=175&ccid=Y%2flA0Juf&simid=608045246916726545&thid=OIP.M63f940d09b9fd7af82665c39bb8c1f5ao0&ajaxhist=0"
I'm new to PC gaming and was dumb enough to think I could make this Video card work in the PC posted above.
http://www.microcenter.com/product/451184/Radeon_R7_360_Overclocked_2GB_GDDR5_Video_Card
I am starting to think ether my PC is simply to shit, or my video card is defective. Although I did hear that any AMD GPU can work with any AMD motherboard as long as it has a PCIEx16 port which mine does, If anyone could help and explain exactly what I'm doing wrong or tell me if I was given false information I would be very thankful. Oh and I also tried to clean my Ram sticks and saw no real difference.
