My hhd mbr damaged and i cant fix it
kane the mask
14
Hi guys
something happen to my wd my book 2 tb , firist thing happen i couldnt acces my hardisk and telling me that it need to be formatted , and next thing it disappeared from my computer list , i can only knew he is there by some programs such partion doctor and test disk etc
i tried to wirte a new mbr by test disk and by partion doctor and it didnt sucess to write a new mbr
its like my hhd has been cursed and there are nothing can fix it
i dont even know why i asked for help , am losing hope but its worth a shot ,
i dont rly want to lose all that 2 tb data anyone pls help 🙁
if you mean WD SmartWare i already did , and its says ( no writable WD SmartWare partition found ) :??:
i tried to fix my hard drive with HDD Regenerator , firist its tell me ( Master boot record of this drive is damged ) when repair starting its says (disk problem - seek failure)
it also said ( connect USB as Internal ) how i can do that ??
sorry but how i can update firmware ?
and backup all data you mean all data on my pc , or only the data on the damaged hdd ?
hirean boot cd and linux cd can reach my damaged drive and backup all the data in it ??
To recover the lost 2TB data, you’d better firstly try a hard drive recovery freeware and then format it to have a try. This freeware has helped my friend retrieve all his inaccessible data from a “not formatted” flash drive. I believe it will help you, too.
If you are interested in it, you can visit here: -http://blog4mark.blogspot.com/2012/11/convert-raw-to-ntfs-without-data-loss.html
The “not formatted” problem often happens because of improper use, virus attack, or even weak power support, etc. Don’t worry!
Note: You should never store new data on this drive to rewrite the original data.
You should never store you important files on only one hard drive.
