My HP laptop suddenly shuts down within an hour after it gets hot. I think my fan is not working properly or maybe not al all.
G-girl
4
My HP laptop suddenly shuts down within an hour after it gets hot. I think my fan is not working properly or maybe not al all. When I turn it on it says that it will be turned off in 15 secs or I should press "Enter" if I want to continue but it's not recommended. I choose to press Enter anyways 'cause I have to use the laptop.
Get the exact model number, go on ebay, and buy a new fan. It's usually not too hard to install.
Or go to a PC repair place and get them to do the same.
You may even find that the fan has simply come unplugged.
This is the exact error message I see on a black screen: The system has detected that a cooling fan is not operating correctly.
Continued operation is not recommended and may cause unpredictable behavior that could result in random shutdown, data loss or possible system damage. The system will shut down in 15 seconds. To prevent shutdown and continue operation, press the Enter key now.
System Fan (90b). No I don't hear nor feel the fan running.
It is an HP 2000 Notebook PC
Thanks for your advice.
