My Humble Build : First Attempt At Custom Liquid Cooling
Durwesh Naeem
222
7
18,695
Recently I made a plan to put a water block on my CPU, i have had a Corsair 900D case for quite a while now and i was running my i7 - 6850K Corsair H115i AIO cooler in push and pull configuration. So i made the following changes , i was advised by people to go for soft tubing as it was my first time. Currently running my CPU at 4.4Ghz @ 1.355V while gaming max temps are 58C and on stress testing on real bench the maximum temps were 68C after running it for 2 hours.
i would like to give a special thanks to
mcnumpty23
for all his help.
Liquid Cooling Components :-
EK - Supremacy EVO - Nickel (Original CSQ)
EK - CoolStream XE 360 (Triple) Radiator
EK - ACF Fitting 13 / 19 MM -Nickel
EK - X3 250 Reservoir
EK - CryoFuel Clear Concentrate Coolant in Distilled Water
EK - TUBE PrimoChillFlex 19.1 / 12.7 MM - Onyx Black
Swiftech MCP655-B G 1 / 4 Special Threaded Edition Pump
Hardware Specifications :-
Corsair Obsidian 900D Super Tower
i7 - 6850k 4.4 GHz @ 1.355V
ROG Rampage V 10th Anniversary Edition x99
G.Skill Trident Z RGB 32 GB 3200Mhz
Zotac GTX 1080Ti AMP! Extreme
ROG Swift PG27AQ 4K G - SYNC IPS / Asus PB287Q 4K
Corsair AX1200i with Cablemod Red Sleeved Cables
NZXT Hue+ Advanced PC Lighting
Corsair K95 RGB Platinum Mechanical Keyboard
Corsair MM200 Mouse Mat
Razer Naga Epic Chroma Wireless Mouse
Sennheiser Game ZER0 Black Headset
Logitech Z906 5.1 Speakers
IMGUR Link : http://imgur.com/gallery/MKhmJ
Looks good but a little messy; soft tubes are indeed good for first timers; I would had rerouted the long tube differently; and i would had gone for reddish pink tubes to complement the custom PSU cables.
And also, i am a huge fan of witchers 3 wild hunt; Nice build and nice wallpaper.
well done man.
theoretically, you'd see even lower temps if the radiator was mounted in front as intake or at the bottom of the case.
next step wold be adding GPU to the loop ?
if so, HWLabs radiators are kinda better. As well as Noctua NF-A14x15 fans 😉
Thanks i know i could have routed the big tube differently but unfortunately its too thick and not too flexible
well you are right, on paper the rad as in flow would give lower temps but the problem remains i do not think i could mount it in the front or the side because of the lack of space and unfortunately i do not think a gpu block for my zotac 1080ti amp extreme is available yet
good luck man and i am glad you appreciated my very first try i know its messy but i am a newbie
Latest posts
