A allwyn4 Reputable Mar 26, 2014 10 0 4,510 Mar 26, 2014 #1 My Internet Cable is dsl but my router's input port is ethernet what should i do? do i need to buy a modem or is there any converter is there to change dsl to ethernet? will it work? guide me
Solution STACKS ON DECK Mar 26, 2014 modem or splitter will do the job for you . dsl connection requires modem to work it
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Mar 26, 2014 Solution #2 modem or splitter will do the job for you . dsl connection requires modem to work it Upvote 0 Downvote Solution
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Mar 26, 2014 #4 glad to help Upvote 0 Downvote
A allwyn4 Reputable Mar 26, 2014 10 0 4,510 Mar 26, 2014 #5 what splitter do i have to use? please help Upvote 0 Downvote
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Mar 26, 2014 #6 dsl splitter are available http://www.newegg.com/Product/Product.aspx?Item=0Y1-003H-00014 but for a dsl connection mostly ADSL , modems are mandatory Upvote 0 Downvote
A allwyn4 Reputable Mar 26, 2014 10 0 4,510 Mar 26, 2014 #7 i bought this http://www.flipkart.com/netgear-jwnr2010-n300-wireless-router/p/itmdpxkcezfz7rhd?pid=RTRDPXKCBHEECZQE&otracker=from-search&srno=t_15&query=wireless+router&ref=39bbd7c8-4552-4c1c-ba16-2aaf4b015e25 it does not have dsl input...;( Upvote 0 Downvote
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Mar 26, 2014 #8 this is a router . it doesn't support dsl . . contact your ISP for that . splitter will not be enough if there is DSL settings behind Upvote 1 Downvote
