Question My laptop battery is okay?
danny009
515
38
10,920
We got this laptop during the covid, it is brand new however I noticed in hwinfo battery wear level is up to %11.7 already. This occurs only when laptop turned off and recharging from the wall. Is this normal? Software says battery and the adapter is ok.
Thank you, danny
danny009
515
38
10,920
Any updates on this matter if you guys don't mind my asking, it is a asus laptop rog g15 (2022) Really like to use it without power cable I mean it is the point of owning a laptop in the first place however wear of battery worrying.
Wear increases a bit (sometimes) when recharging the battery from the wall, I'm using an extension cable, perhaps that is the reason? I tested both max lifespan mode and asus default battery health modes, did not changed anything.
danny009
515
38
10,920
charging battery will get wearout. keep it off will save it
Okay I got that more than 3 years old battery, but I really did not used this laptop at all, just some weekend gaming in 30fps low to mid in game settings, most of the time laptop was turned off and didn't notice any insanely high temps on any hardware, CPU/GPU stays under 65c and storage plus RAM is always around 55c. I did read high temps to cause also wearout the battery so this isn't my case then.
Is there a somekind website where I can make up the battery lifespan? Like MSI power supply voltage calculator,
