my laptop turned off without warning and not turn back on and if i plug it ,it does not notice that it plugged
Hi,
Please check whether your PC has any overheating issue.
You can perform a power drain by removing the battery and holding the power button for 10-15 seconds. This is remove the static charge from the motherboard.
Once the PC boot to Windows, deleted all temporary files to increase the efficiency of the OS.
>>press Win + R keys together. In Run command box, type "temp" and click OK. Delete all the files listed in the folder.
>>Again from Run, type "%temp%" and click OK. Delete all the file s from this folder too.
These file deletion will not affect the operation of your PC.
To check whether it is a software or hardware issue, please use the PC in safe mode and check whether you are facing the same issue or not.
Hi,
