Hello
I have a Windows 7 Lenovo laptop, and I use it with my 22" Sharp TV/monitor (with a standard PC cable). It's widescreen, and I have the resolution set at 1366 x 768.
This has worked without issue for over three years now, however earlier today the display on my TV squashed itself into the middle of the screen (something like you would see in a traditional 4:3 monitor), however the resolution hadn't been altered once.
I was using my PC earlier today with no problems, and this seemed to happen out of nowhere. Regular TV and my Xbox both still happily play at full screen with no distortion / squashing.
When I right click on the desktop, Graphics Options > Panel Fit > maintain Aspect Ratio brings my display back to the right proportions, but off centre (there is a larger border on the left than on the right), and with the clock and most of the other icons on that side of the screen pushed off (and obviously with a very large black border).
I've tried turning everything off, unplugging everything and firing it all back up but this hasn't helped. When I disconnet the TV the screen on my laptop is normal, however when I change the display options settings to mirror both screens the same border appears on my Laptop.
I've also tried a different VGA cable and this hasn't worked.
I have a Mobile Intel 4 Series Express Chipset, and according to the Windows automatic update the driver for this is already up to date (also I cannot understand how, after over three years of working just fine, the drivers would suddenly go mad and cause this).
CCleaner and MalwareBytes have been ran but haven't solved the problem (CCleaner found 947 other problems though!!), and Comodo and Avast are up to date.
I have absolutely no idea what has caused this, and everything I thought might be the solution has so far failed. This is my Display Configuration file exported as .txt...
System Information report written at: 04/28/14 15:32:37
System Name: MATTHEW-PC
[Display]
Item Value
Name Mobile Intel(R) 4 Series Express Chipset Family
PNP Device ID PCI\VEN_8086&DEV_2A42&SUBSYS_3A0217AA&REV_09\3&11583659&2&10
Adapter Type Mobile Intel(R) 4 Series Express Chipset Family, Intel Corporation compatible
Adapter Description Mobile Intel(R) 4 Series Express Chipset Family
Adapter RAM 1.25 GB (1,340,393,472 bytes)
Installed Drivers igdumdx32.dll,igd10umd32.dll,igd10umd32.dll
Driver Version 8.15.10.1840
INF File oem5.inf (iCNT0 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1366 x 768 x 59 hertz
Bits/Pixel 32
Memory Address 0xF4000000-0xF43FFFFF
Memory Address 0xD0000000-0xDFFFFFFF
I/O Port 0x00001800-0x00001807
IRQ Channel IRQ 4294967293
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd32.sys (8.15.10.1840, 5.65 MB (5,922,816 bytes), 09/06/2010 21:30)
PNP Device ID PCI\VEN_8086&DEV_2A43&SUBSYS_3A0217AA&REV_09\3&11583659&2&11
Adapter Type Not Available, Intel Corporation compatible
Adapter RAM Not Available
INF File oem5.inf (iCNT1 section)
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xF4400000-0xF44FFFFF
Thank you in advance for your help (any is appreciated).
M
[Display]
Item Value
Bits/Pixel 32
M
