My monitor keeps dimming
Hello_worldavi
Commendable
May 23, 2017
14
Hey guys i got this problem i cant seem to work out my monitor keeps dimming at random points and ive tried seeting up the time required before it happens, for examlpe in certain meanus it will dim to being very hard to see and then at other points it will just brighten right back up then if i open up the same menu again it will dim as if i was idle
Im using windows 10 at the moment and the problem persists even in my BI0S
I don't see evidence of a light sensor on the monitor and can't access the manual from my current location. Check your monitor's menu settings to see if there any settings related to auto-dimming.
Have you connected this this monitor to any other systems to see if the behavior is consistent with other devices?
monitor, see above reply for link to the model purchased
