My monitor says that there is no DVI signal URGENT HELP!!!!
Ethann
Commendable
Feb 2, 2017
4
So I recently bought a new pc and monitor. When I connected the DVI cable from the pc to the monitor, when I turned it on it said "DVI No Signal". I called technical support and they told me to take out the graphics card and put it back in, still didn't work. I then removed the battery and replaced it, still didn't work. Need help quickly!
Hello... List your PC, CPU, OS and Video card specs for us.
1) If you have a Video Card you need to plug into the different DVI connectors, on it, and look for the active one after boot.
2) If you have CPU, or MB with a integrated video option, then you need to plug into the Motherboard, and look for a active one after boot.
