My network adapter won't connect to a wireless access point
ibrahim011
5
My windows 10 Asus X55U is not able to connect to any access point. It has been months since I have upgraded to windows 10 so I doubt there is a problem with the actual operating system. I have tried doing a system update, a fresh install of the wifi driver, and I have rebooted my laptop several times. I don't think the range of the access point is a problem, as I have set up an another router in my room, and I still have the same problem. Every time I try to connect to an Access point the adapter automatically disables , and then re-enables. I thought this to be an odd behavior. Any solutions ?
I'm thinking there is something physically wrong with the wifi card, but I don't know how to check
Which exact chipset driver should I update ? I updated the Asus Wireless Radio Control, but nothing changed
