D deanjoshua216 Prominent Dec 31, 2017 44 0 530 Jan 17, 2019 #1 I built my new pc today and when i plug in my headset the mic isn't recognized
Solution Phillip Corcoran Jan 17, 2019 If headset has a single "combo" jack-plug, but PC has separate mic & headphone jacks, you'll need and adapter cable to "split" the headset jack-plug in to separate mic/headphone plugs - - like this one: https://www.amazon.co.uk/StarTech-com-Position-Headset-Splitter-Adapter-Black/dp/B0058DOWH6/ref=sr_1_51?ie=UTF8&qid=1547725455&sr=8-51&keywords=headset+adapter
-HH- Dignified Oct 20, 2014 3,534 3 15,465 Jan 17, 2019 #2 Hey, is the headset USB? - What headset is it? Upvote 0 Downvote
D deanjoshua216 Prominent Dec 31, 2017 44 0 530 Jan 17, 2019 #3 -HH- : Hey, is the headset USB? - What headset is it? its a hyperx cloud stinger and just has a 3.5mm cable no usb Upvote 0 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Jan 17, 2019 Solution #4 If headset has a single "combo" jack-plug, but PC has separate mic & headphone jacks, you'll need and adapter cable to "split" the headset jack-plug in to separate mic/headphone plugs - - like this one: https://www.amazon.co.uk/StarTech-com-Position-Headset-Splitter-Adapter-Black/dp/B0058DOWH6/ref=sr_1_51?ie=UTF8&qid=1547725455&sr=8-51&keywords=headset+adapter Upvote 0 Downvote Solution
D deanjoshua216 Prominent Dec 31, 2017 44 0 530 Jan 17, 2019 #5 Phillip Corcoran : If headset has a single "combo" jack-plug, but PC has separate mic & headphone jacks, you'll need and adapter cable to "split" the headset jack-plug in to separate mic/headphone plugs - - like this one: https://www.amazon.co.uk/StarTech-com-Position-Headset-Splitter-Adapter-Black/dp/B0058DOWH6/ref=sr_1_51?ie=UTF8&qid=1547725455&sr=8-51&keywords=headset+adapter i have one and tried it still nothing Upvote 0 Downvote
D deanjoshua216 Prominent Dec 31, 2017 44 0 530 Jan 17, 2019 #6 Phillip Corcoran : If headset has a single "combo" jack-plug, but PC has separate mic & headphone jacks, you'll need and adapter cable to "split" the headset jack-plug in to separate mic/headphone plugs - - like this one: https://www.amazon.co.uk/StarTech-com-Position-Headset-Splitter-Adapter-Black/dp/B0058DOWH6/ref=sr_1_51?ie=UTF8&qid=1547725455&sr=8-51&keywords=headset+adapter ok for some reason i had to plug the cables into the back of my pc instead of the front ports so thanks for the advice Upvote 0 Downvote
-HH- Dignified Oct 20, 2014 3,534 3 15,465 Jan 17, 2019 #7 maybe your front panel audio isn't working. Might be worth opening up your PC and checking Upvote 0 Downvote
