Question My newly built pc's cpu temps spike.
Oct 11, 2019
4
Hey there i am using a ryzen 5 2600x with stock cooler and an asus x470 prime-pro. I have checked on the internet the average temps i should be expecting, since i am somewhat of a beginner on both pc build and amd builds in general. Idle temps are around 50 degrees, and on load 70. Did a cpu-z stress test and it rose to 85 degrees in under a minute.
This is the results after 30 mins of apex legends on almost max.
Edit: This all started because around 2 hours ago when i was playing apex, i saw that my temps were aroudn 85 degrees and didnt lower even after minutes. Instantly lowered all setings on apex and it lowered to the normal 70 degrees but on low.
Edit2: Forgot to put this
View: https://imgur.com/a/CaS6uYV
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model PRIME X470-PRO (0x000003AE - 0x9EAE4942)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8665
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8665
LPCIO Revision ID 0x6
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 86 65 06 40 37 D0 FF 01 00 95 00 49 85 08 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT8665
Voltage 0 1.35 Volts [0x7C] (CPU VCORE)
Voltage 1 2.51 Volts [0xE6] (VIN1)
Voltage 2 2.03 Volts [0xBA] (VIN2)
Voltage 3 1.99 Volts [0xB7] (VIN3)
Voltage 4 0.03 Volts [0x3] (VIN4)
Voltage 5 0.03 Volts [0x3] (VIN5)
Voltage 6 0.03 Volts [0x3] (VIN6)
Voltage 7 1.68 Volts [0x9A] (VIN7)
Temperature 0 56 degC (132 degF) [0x38] (TMPIN0)
Temperature 1 42 degC (107 degF) [0x2A] (TMPIN1)
Temperature 2 53 degC (127 degF) [0x35] (TMPIN2)
Fan 0 2402 RPM [0x119] (CPU)
Fan 1 915 RPM [0x2E2] (FANIN1)
Fan 3 1230 RPM [0x225] (FANIN3)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 09 7C F7 BE 00 00 00 00 00 C0 44 08 30 1E EC FF
10 FF E0 77 70 C0 80 80 80 01 02 FF FD F5 D7 80 00
20 7C E5 BA B7 03 03 03 9A 95 38 2A 34 34 34 34 9B
30 E5 FD DF FB BF F3 DD 4B FF BB E2 D9 EE F8 7E F5
40 71 F8 AD 6F FC 5E E7 71 AD 6A D4 00 5F 40 EA 7F
50 FF 38 7F 7F 7F 40 00 00 90 00 00 12 60 00 00 00
60 80 14 46 33 00 00 0F BE 80 1E 46 99 14 00 0F DA
70 80 1E 46 99 14 00 0F DA 80 1E 46 99 14 00 0F DA
80 2A 02 FF FF 00 00 00 00 00 00 00 00 00 3E 00 5A
90 00 00 00 FF FF 00 00 FF 42 99 00 00 01 05 E0 38
A0 7F 7F 7F 80 00 00 0F 80 80 7F 7F FF 00 00 0F FF
B0 F7 00 00 00 DA AF FD EE FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor AMD ADL
Voltage 2 0.81 Volts [0x32C] (SOC)
Power 0 16.00 W (GPU)
Temperature 0 49 degC (120 degF) [0x31] (GPU)
Temperature 1 49 degC (120 degF) [0x31] (Memory)
Temperature 5 0 degC (32 degF) [0x0] (VDDC VR)
Temperature 6 0 degC (32 degF) [0x0] (MVDD VR)
Fan 0 0 RPM [0x0] (GPU #0)
Clock Speed 0 851.00 MHz [0x353] (Graphics)
Clock Speed 1 281.00 MHz [0x119] (Memory)
Clock Speed 2 545.00 MHz [0x221] (Processor)
Processors
Number of sockets 1
Number of threads 12
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- CCX 1
-- Core 3 (ID 4)
-- Thread 6 8
-- Thread 7 9
-- Core 4 (ID 5)
-- Thread 8 10
-- Thread 9 11
-- Core 5 (ID 6)
-- Thread 10 12
-- Thread 11 13
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Manufacturer AuthenticAMD
Name AMD Ryzen 5 2600X
Codename Pinnacle Ridge
Specification AMD Ryzen 5 2600X Six-Core Processor
Package Socket AM4 (1331)
CPUID F.8.2
Extended CPUID 17.8
Core Stepping PiR-B2
Technology 12 nm
TDP Limit 95.0 Watts
Tjmax 95.0 °C
Core Speed 4046.1 MHz
Multiplier x Bus Speed 40.5 x 99.9 MHz
Base frequency (cores) 99.9 MHz
Base frequency (ext.) 99.8 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x800820C
L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 6 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 6 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 x 8 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Fh
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 6 thread(s)
FID/VID Control yes
# of P-States 3
P-State FID 0x890 - VID 0x3A (36.00x - 1.188 V)
P-State FID 0x880 - VID 0x55 (32.00x - 1.019 V)
P-State FID 0xC84 - VID 0x72 (22.00x - 0.837 V)
PStateReg 0x80000000-0x490E8890
PStateReg 0x80000000-0x48154880
PStateReg 0x80000000-0x459C8C84
PStateReg 0x00000000-0x00000000
Package Type 0x2
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Power Unit 0.0
Attached device PCI device at bus 0, device 24, function 0
100 00000000 E0000001 00000000 00000000
110 00000083 00041000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 00000000 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
100 00000000 00000003 00000000 00000000
110 00100000 00100020 00100020 00100000
120 00100000 00000000 00000000 00000000
130 00000000 00000000 00100000 00100020
140 00100020 00000000 00100000 00000000
160 00001020 00000000 00000000 00000000
170 00000000 0000810D 00000000 00008105
180 00000000 00000040 00000000 00000030
190 00000000 00000040 0000003E 00000001
1A0 48201020 00000000 00000000 00000000
1B0 0003038F 00000048 00000040 00000000
1C0 00000020 00000034 01003030 00000000
1E0 00000004 0001014E 00000048 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
130 00010001 00010001 00010001 00010001
140 00010001 00010001 00010001 00010001
Attached device PCI device at bus 0, device 24, function 3
100 00000000 143F1FC2 0380FC40 00000000
Attached device PCI device at bus 0, device 24, function 4
100 00000000 0000015F 000009FF 000002BF
110 00400000 00010000 0001E000 0001FF01
120 0001FF00 00010000 0001FF02 0001FF07
130 0001FF03 00010000 0001FF02 00000000
180 000F0F0F 000F0F0F 001B1B1B 000F0F0F
190 000F0F0F 000F0F0F 00000000 00000000
Attached device PCI device at bus 0, device 24, function 5
100 00000000 04000000 00700281 00000000
190 00000008 00000100 00000000 00000000
1A0 00000000 00000040 00200000 00000000
Attached device PCI device at bus 0, device 24, function 6
130 00000000 00000000 FFFF0000 00000000
140 00000006 00000000 00000000 00000000
1F0 00000000 00000000 00000083 90000000
Attached device PCI device at bus 0, device 24, function 7
SMU Version 43.21.00
TDP/TJMAX 0x5F005F
TCTL Offset 0x0
Core Perf #0 0xFF625410
Temperature 0 56 degC (133 degF) (Package (Node 0))
Voltage 0 1.34 Volts (CPU VDD (Node 0))
Voltage 1 1.34 Volts (VID #0)
Voltage 2 1.34 Volts (VID #1)
Voltage 3 1.34 Volts (VID #2)
Voltage 4 1.34 Volts (VID #3)
Voltage 5 1.34 Volts (VID #4)
Voltage 6 1.34 Volts (VID #5)
Power 00 42.45 W (Package)
Power 01 3.49 W (Core #0)
Power 02 6.45 W (Core #1)
Power 03 3.84 W (Core #2)
Power 04 2.41 W (Core #3)
Power 05 2.61 W (Core #4)
Power 06 2.50 W (Core #5)
Power 07 22.74 W (Cores)
Clock Speed 0 4046.05 MHz (Core #0)
Clock Speed 1 4046.05 MHz (Core #1)
Clock Speed 2 4046.05 MHz (Core #2)
Clock Speed 3 4046.05 MHz (Core #3)
Clock Speed 4 4046.05 MHz (Core #4)
Clock Speed 5 4046.05 MHz (Core #5)
Core 0 max ratio (effective) 41.3
Core 1 max ratio (effective) 41.3
Core 2 max ratio (effective) 41.3
Core 3 max ratio (effective) 41.3
Core 4 max ratio (effective) 41.5
Core 5 max ratio (effective) 41.3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00800F82 0x000C0800 0x7ED8320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000011
0x00000006 0x00000004 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x209C01A9 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x0000000D 0x0000000F 0x00000340 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x8000001F 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00800F82 0x20000000 0x35C233FF 0x2FD3FBFF
0x80000002 0x20444D41 0x657A7952 0x2035206E 0x30303632
0x80000003 0x69532058 0x6F432D78 0x50206572 0x65636F72
0x80000004 0x726F7373 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF40 0xFF40FF40 0x20080140 0x40040140
0x80000006 0x26006400 0x66006400 0x02006140 0x00808140
0x80000007 0x00000000 0x0000001B 0x00000000 0x00006799
0x80000008 0x00003030 0x00001007 0x0000400B 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00008000 0x00000000 0x0001BCFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F040 0x00000000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000003FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000001D 0x00004121 0x01C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x00C0003F 0x000000FF 0x00000000
0x8000001D 0x00004143 0x01C0003F 0x000003FF 0x00000002
0x8000001D 0x00014163 0x03C0003F 0x00001FFF 0x00000001
0x8000001E 0x00000000 0x00000100 0x00000000 0x00000000
0x8000001F 0x0000000F 0x0000016F 0x0000000F 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010058 0x00000000 0xF8000019
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000888A2
MSR 0xC0010064 0x80000000 0x490E8890
MSR 0xC0010065 0x80000000 0x48154880
MSR 0xC0010066 0x80000000 0x459C8C84
MSR 0xC0010067 0x00000000 0x00000000
MSR 0xC0010068 0x00000000 0x00000000
MSR 0xC0010069 0x00000000 0x00000000
MSR 0xC001006A 0x00000000 0x00000000
MSR 0xC001006B 0x00000000 0x00000000
MSR 0xC0010299 0x00000000 0x000A1003
MSR 0xC001029B 0x00000000 0x142CEAFD
MSR 0xC001029A 0x00000000 0x193D0BF1
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x00800F82 0x010C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000001 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC001029B 0x00000000 0x142E39DB
MSR 0xC001029A 0x00000000 0x193D4043
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00800F82 0x020C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000002 0x00000101 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x142FCAF0
MSR 0xC001029A 0x00000000 0x1C5266B1
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
CPUID
0x00000001 0x00800F82 0x030C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000003 0x00000101 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x143111FA
MSR 0xC001029A 0x00000000 0x1C529CFD
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00800F82 0x040C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000004 0x00000102 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x143227C9
MSR 0xC001029A 0x00000000 0x182C46E9
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x00800F82 0x050C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000005 0x00000102 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x1433518B
MSR 0xC001029A 0x00000000 0x182C7932
CPU Thread 6
APIC ID 8
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x00800F82 0x080C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000008 0x00000104 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x1434652A
MSR 0xC001029A 0x00000000 0x1CA83EC9
CPU Thread 7
APIC ID 9
Topology Processor ID 0, Core ID 4, Thread ID 1
CPUID
0x00000001 0x00800F82 0x090C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x00000009 0x00000104 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x143594DA
MSR 0xC001029A 0x00000000 0x1CA86FD5
CPU Thread 8
APIC ID 10
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x00800F82 0x0A0C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000A 0x00000105 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x1436B822
MSR 0xC001029A 0x00000000 0x192D112A
CPU Thread 9
APIC ID 11
Topology Processor ID 0, Core ID 5, Thread ID 1
CPUID
0x00000001 0x00800F82 0x0B0C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000B 0x00000105 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x14380BB3
MSR 0xC001029A 0x00000000 0x192D4637
CPU Thread 10
APIC ID 12
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x00800F82 0x0C0C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000C 0x00000106 0x00000000 0x00000000
MSR 0xC0010293 0x00000000 0x000988A1
MSR 0xC001029B 0x00000000 0x143995BE
MSR 0xC001029A 0x00000000 0x19B4327A
CPU Thread 11
APIC ID 13
Topology Processor ID 0, Core ID 6, Thread ID 1
CPUID
0x00000001 0x00800F82 0x0D0C0800 0x7ED8320B 0x178BFBFF
0x8000001E 0x0000000D 0x00000106 0x00000000 0x00000000
MSR 0xC001029B 0x00000000 0x143AEBF0
MSR 0xC001029A 0x00000000 0x19B468F6
Storage
Drive 0
Name HKVSN HS-SSD-C100/480G
Revision R1029A
Serial 30002791567
Capacity 447.1 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 446.5 GBytes (32.0 percent available)
Drive 1
Name KINGSTON SV300S37A120G
Revision 605ABBF1
Serial 50026B7259096D4A
Capacity 111.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 2
Name TOSHIBA HDWD110
Revision MS2OA8R0
Serial 593LJU4FS
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC084
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x0E6A, product=0x02C0
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2150100
Name AMD Radeon RX Vega 56
Board Manufacturer 0x1DA2 (0xE37F)
Codename Vega 10 XL
Technology 14 nm
Memory size 8176 MB
Memory type HBM2
PCI device bus 10 (0xA), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1DA2)
Model ID 0x687F (0xE37F)
Revision ID 0xC3
Performance Level 0
Core clock 26.0 MHz
Shader clock 16.0 MHz
Memory clock 267.0 MHz
Performance Level 1
Core clock 26.0 MHz
Monitor 0
Model LEN D24f-10 ()
ID LEN65EB
Serial
Manufacturing Date Week 16, Year 2019
Size 23.4 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-180 kHz
Vertical Freq. Range 48-144 Hz
Max Pixel Clock 340 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Newtonius
Upstanding
Sep 25, 2019
415
78
340
26
Check on CPU-Z (also try ryzen master to monitor your cpu) what your core voltages are. If you're voltages are spiking up to 1.4-1.5 then that's the problem, you'll want to drop that to around 1.325 for all cores.
If it's not a voltage problem, then it's an IHS (integrated heat spreader, the lid on your CPU) problem. Either the CPU's IHS is not making proper contact with the CPU's die or the contact between your air cooler and your CPU IHS isn't fully making contact, which is possible if you didn't install the air cooler on properly with thermal paste or if the IHS itself is warped.
Oct 11, 2019
4
While playing apex
View: https://imgur.com/a/t9qJYbS
