My newly built system is freezing
chris7844
36
I built a new computer rig with the following new components:
CPU- FX-8350
Motherboard- ASUS Sabertooth 990FX rev.2
16 gigs of 1600 ddr3 ram (G2)
Evega GTX 770 Dual 4gb
HD- 500gb barracuda
Case-NZXT Source 530 (7 fans- no controllers)
CM Seidon water cooler (bluelight)
Power Supply Corsair HX 750w
(1) Super multi and (1) Super multi bluray drive
My computer freezes after three or four hours of use, idle or in game play.
Temps hit the low 40's at peak use and mid to lower 30's while idle. No red LED's show and no beeps sound. I'm not overclocking it. I play League and minecraft. Can you help me?
I have just installed all the latest drivers for each new component. I'll let you know the outcome 24 hours from now. But, I'm wondering if the HX 750 is enough power for my rig. It's been said that power usage should be buffered by 30 % above cost. The GTX 770 requires a 600w psu at minimum and 30% of 600 is 180. Maybe an 800w or better..., we'll see. I don't want to jeopardize my equipment on theory alone.
750W PSU plenty for GTX-770 even for SLI so there is some software problem rather than PSU problem :)
New symptom: computer freezes, but this time I'm watching Netflix and the video feed slows down just prior to the freeze. While the feed is slowing, the computer disconnects the sound device. Like watching something in slow motion as I slowly lose complete control.
No, BETA driver should be OK, right now I'm also using BETA driver and it works just fine.
I recommend you to try to run your system with other HDD, I had almost same problem and I found that it was a bad (dying) HDD, it's still dying 😀
Something I've also noticed about my rig is that it's more prone to freeze from a cold start. When I get home from work, it freezes within an hour. When I restart it, it goes many hours before it freezes.
I installed a new hard drive and a ssd. Incidentally, I was checking my settings in the bios and I found some settings off. It had chosen 1333 settings and under-powered my (1600) ram at 1.5v. The ram I use is 1.65v. It also had my timings at 11-11-11-28. The real timings are 9-9-9-24. Do you think this could have skewed things?
Not really, RAM speed shouldn't freeze your PC but you have to enable XMP in BIOS to have good performance :)
It froze again, but this time it gave me a bsod (0x000000F4, 0xFFFFA800F145B30). I wonder if the option of using the UEFI and legacy boot simultaneously might be the problem.
I made some research and found that it might be driver or HDD problem so it's not your BIOS, try to find another HDD and try to run your PC (to make sure that it's not software) and/or reinstall all your drivers :)
It took longer to freeze this time. Played games and videos without any problems, up until about five minutes ago. I was playing minecraft when all of a sudden the mouse stopped working. Mind you, everything else kept working. Then while trying to get to my event logger with just a keyboard, it stopped working with the sound. For couple more minutes everything else appeared to continue. The computer clock kept ticking away until the bsod showed up.
Oh, 0x000000f4 is an error code for wlan driver that comes with some of the Sabertooth 990FX v2 and v1 boards. The driver gives a contradicting command (tells it to stop and go at the same time) to the computer that cause it to hang up with a bsod 0x000000f4 error. I downloaded Microsoft's hotfix for it. Now all I need to do is see if the bluescreen returns. The game and videos I've been using are online. Hopefully this is it. Another wait and see monitoring.
Let us know about results :)
Get this, due to those hotfixes that I installed, I incidentally installed code debugger. I received the following: CODE 0116 - 0x000000000000003, FFFFA800C6D6010 (TIMES 4) Anyway, code 0116 = VIDEO_TDR_ERROR-- I get the feeling this is related to my GTX 770. Since my 90 days to get the extended warranty from newegg is still valid, I went ahead and purchased it. Free replacement /no questions asked makes me feel better. Is a VIDEO_TDR_ERROR fixable?
Could you post BSOD picture?
Got a new one:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF80002DBB921
BCP3: FFFFF88006586970
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\052714-26988-01.dmp
C:\Users\Chris\AppData\Local\Temp\WER-74849-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
