My newly built system is freezing
chris7844
36
I built a new computer rig with the following new components:
CPU- FX-8350
Motherboard- ASUS Sabertooth 990FX rev.2
16 gigs of 1600 ddr3 ram (G2)
Evega GTX 770 Dual 4gb
HD- 500gb barracuda
Case-NZXT Source 530 (7 fans- no controllers)
CM Seidon water cooler (bluelight)
Power Supply Corsair HX 750w
(1) Super multi and (1) Super multi bluray drive
My computer freezes after three or four hours of use, idle or in game play.
Temps hit the low 40's at peak use and mid to lower 30's while idle. No red LED's show and no beeps sound. I'm not overclocking it. I play League and minecraft. Can you help me?
I could kick myself for not doing this earlier. I removed the GTX 770 and it's software and put the HD 6850 in with the latest driver. The freezes stopped. Video quality went up with no jagged edges. My FPS increased when I removed the GTX 770 and replaced it with the HD 6850. I'm willing to bet that the gpu wasn't firing correctly. I RMAed it and in exchange for another hundred, I'm getting the GTX 780. We'll see how it works.
Sorry for late posting (in my country was night 😀).
So Yeah! if you FPS increased with older GPU then its definitely GPU problem.
Good Luck! with GTX-780
Okay, it froze again, but no bsod. Symptoms:
1- mouse stopped working
2- everything contiued but in slow motion
3- sound stopped and disconnected
4- was able to get to a task manager with keyboard, then it stopped
5- usb devices disconnected and became unrecognized
6 then it just froze except the clock kept on ticking (watched a couple minutes)
7. hit reset button and everything came back like it didn't happen
Event logger warnings before and after freeze:
Warning--The TransactionManager (TmId={daccf044-e5a4-11e3-b344-806e6f6e6963}, LogPath=\SystemRoot\System32\Config\TxR\{daccf042-e5a4-11e3-b344-806e6f6e6963}.TM) has failed to advance its log tail, due to the transaction (UOW={daccf06b-e5a4-11e3-b344-40167e2894e6}, Description='') being unresolved for some time. The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services. Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Error-- The server {14083C53-B8E7-48E4-9320-811F3478C4A4} did not register with DCOM within the required timeout.
Warning-- The TransactionManager (TmId={daccf044-e5a4-11e3-b344-806e6f6e6963}, LogPath=\SystemRoot\System32\Config\TxR\{daccf042-e5a4-11e3-b344-806e6f6e6963}.TM) has failed to advance its log tail, due to the transaction (UOW={daccf06b-e5a4-11e3-b344-40167e2894e6}, Description='') being unresolved for some time. The transaction must be forced to resolve in order for the TransactionManager to continue to provide transactional services. Forcing the incorrect outcome may cause data corruption in any subordinate ResourceManagers or Transactionmanagers.
Critical-- The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Error-- The previous system shutdown at 10:40:39 PM on ‎5/‎28/‎2014 was unexpected.
Error-- The Distributed Transaction Coordinator service terminated with service-specific error %%-1073737669.
Error-- The Group Policy Client service did not shut down properly after receiving a preshutdown control.
Did you install drivers from Asus?
If you have installed delete them because that {14083C53-B8E7-48E4-9320-811F3478C4A4} code appears from AsusFanControlService.
Then try this
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/how-do-you-fix-the-event-viewer-warning-the/12eb2286-c6d3-441f-98b5-a4b44d41ba44
Well I tried again without asus drivers except for the lan driver and the following happened: usb devices became unresponsive and disconnected. and Netflix remained on for over an hour in slow motion without sound. Didn't freeze and my components remained just warm.
ERRORS:
The server {E10F6C3A-F1AE-4ADC-AA9D-2FE65525666E} did not register with DCOM within the required timeout
The AMD FUEL Service service terminated unexpectedly. It has done this 1 time(s).
The Realtek11nCU service is marked as an interactive service. However, the system is configured to not allow interactive services. This service may not function properly.
The previous system shutdown at 9:39:27 PM on ‎5/‎29/‎2014 was unexpected.
- System
- Provider
[ Name] amdkmdag
- EventID 62464
[ Qualifiers] 16384
Level 4
Task 61
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-05-30T03:15:22.340728500Z
EventRecordID 3681
Channel System
Computer Chris-PC
Security
- EventData
00006000010000003D00000000F40040000000000000000000000000000000000000000000000000FFFFFFFF000206580000000000000000030000000A000000000000000FF97F0000803E003C00000000000000030000000B00000000000000030000000B00000000000000030000000B00000000000000030000000A0000000000000003000000
Binary data:
In Words
0000: 00600000 00000001 0000003D 4000F400
0008: 00000000 00000000 00000000 00000000
0010: 00000000 00000000 FFFFFFFF 58060200
0018: 00000000 00000000 00000003 0000000A
0020: 00000000 007FF90F 003E8000 0000003C
0028: 00000000 00000003 0000000B 00000000
0030: 00000003 0000000B 00000000 00000003
0038: 0000000B 00000000 00000003 0000000A
0040: 00000000 00000003
In Bytes
0000: 00 00 60 00 01 00 00 00 ..`.....
0008: 3D 00 00 00 00 F4 00 40 =....ô.@
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: FF FF FF FF 00 02 06 58 ÿÿÿÿ...X
0030: 00 00 00 00 00 00 00 00 ........
0038: 03 00 00 00 0A 00 00 00 ........
0040: 00 00 00 00 0F F9 7F 00 .....ù.
0048: 00 80 3E 00 3C 00 00 00 .€>.<...
0050: 00 00 00 00 03 00 00 00 ........
0058: 0B 00 00 00 00 00 00 00 ........
0060: 03 00 00 00 0B 00 00 00 ........
0068: 00 00 00 00 03 00 00 00 ........
0070: 0B 00 00 00 00 00 00 00 ........
0078: 03 00 00 00 0A 00 00 00 ........
0080: 00 00 00 00 03 00 00 00 ........
EventData
10:52:44 PM
‎5/‎29/‎2014
3556
DE07050004001D00160034002C008300DE07050005001E00030034002C008300600900003C000000010000006009000000000000B00400000100000000000000
Binary data:
In Words
0000: 000507DE 001D0004 00340016 0083002C
0008: 000507DE 001E0005 00340003 0083002C
0010: 00000960 0000003C 00000001 00000960
0018: 00000000 000004B0 00000001 00000000
In Bytes
0000: DE 07 05 00 04 00 1D 00 Þ.......
0008: 16 00 34 00 2C 00 83 00 ..4.,.ƒ.
0010: DE 07 05 00 05 00 1E 00 Þ.......
0018: 03 00 34 00 2C 00 83 00 ..4.,.ƒ.
0020: 60 09 00 00 3C 00 00 00 `...<...
0028: 01 00 00 00 60 09 00 00 ....`...
0030: 00 00 00 00 B0 04 00 00 ....°...
0038: 01 00 00 00 00 00 00 00 ........
- System
- Provider
[ Name] Microsoft-Windows-DNS-Client
[ Guid] {1C95126E-7EEA-49A9-A3FE-A378B03DDB4D}
EventID 1014
Version 0
Level 3
Task 0
Opcode 0
Keywords 0x4000000000000000
- TimeCreated
[ SystemTime] 2014-05-30T03:39:23.698168000Z
EventRecordID 3689
Correlation
- Execution
[ ProcessID] 1260
[ ThreadID] 3556
Channel System
Computer Chris-PC
- Security
[ UserID] S-1-5-20
- EventData
QueryName bn1msgr1011122.gateway.messenger.live.com
AddressLength 16
Address 02000035C0A801010000000000000000
Received this too:
Possible Memory Leak. Application (C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted) (PID: 776) has passed a non-NULL pointer to RPC for an [out] parameter marked [allocate(all_nodes)]. [allocate(all_nodes)] parameters are always reallocated; if the original pointer contained the address of valid memory, that memory will be leaked. The call originated on the interface with UUID ({3f31c91e-2545-4b7b-9311-9529e8bffef6}), Method number (20). User Action: Contact your application vendor for an updated version of the application.
Windows Management Instrumentation ADAP failed to connect to namespace \\.\root\cimv2 with the following error 0x80070057
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Server service, but this action failed with the following error:
An instance of the service is already running.
Faulting application name: svchost.exe_ProfSvc, version: 6.1.7600.16385, time stamp: 0x4a5bc3c1
Faulting module name: ntdll.dll, version: 6.1.7601.18247, time stamp: 0x521eaf24
Exception code: 0xc0000005
Fault offset: 0x000000000000e1e1
Faulting process id: 0x3dc
Faulting application start time: 0x01cf7bdfd864e580
Faulting application path: C:\Windows\system32\svchost.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 45254f1a-e7d3-11e3-9b70-ba241beee8f4
Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x517f39a1
Faulting module name: Device.dll, version: 4.1.0.0, time stamp: 0x4f55e10b
Fault offset: 0x00000000000033c1
Faulting process id: 0x5c8
Faulting application start time: 0x01cf7bdfb42cecee
Faulting application path: C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe
Faulting module path: C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Device.dll
Report Id: fd5b0f62-e7d2-11e3-8620-db5a32c731f5
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS, please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i.
