This will be a bit long, I give you all the info I can.
I'm a retro PC enthusiast, and I have several PCs.
Recently I encountered a really odd problem.
None of my optical drives read CDs while no issue with DVDs with the combo drives.
It doesn't matter if the disc is a factory printed legal copy or home written.
There were no file transfer between the PCs. They weren't even on the same network.
Some of them never were connected to a network. 2 of them never even were in the same city when the problem occured.
The problen doesn't relate to OS, PSU or motherboard.
What I did so far:
Switched the drives between the PCs.
Did more than one BIOS reset.
Flashed a new firmware on one of the drives.
Tested without HDD, tested on primary and secondory IDE channel.
Tested both as master and slave.
Tested under windows XP and 2000.
Removed the drivers and drives, booted the setup without a drive phisically installed then added it back.
The PCs are a Coppermine based Celeron, a Coppermine Pentium 3, a Tualatin Pentium 3 and a Prescott Celeron D (soon Northwood Pentium 4). I can give detailed specs if needed.
The Coppermine Celeron was a gift from a coworker, It's the same setup than it was when I got it and no part of it had any contact with the rest, physical or galvanic at all, and even that doesn't read CDs. Though I only tried my legal copy of Morrowind since I installed a Windows on it.
The CDs are good, my everyday PC reads them fine, and I see it more than unlikely that 4 drives die in 4 entirely separate PCs or that 4 entirely separate motherboards die the same way in a short time. Even those drives or PCs do it that I never used before.
Sometimes, though really rarely the drives do make an exception and willing to read a CD, that's how I was able to install a Windows 2000 on the Prescott based system. That was the only CD it read (neither XP, nor Win98 or Win 95) and only that one time.
What I did so far:
