My PC doesn't recognize my VGA monitor
AnyOnePT
46
Hello, i just built my PC 20 min ago, but after turning it on(all the LEDs,fans working) my monitor stays black.
PC specs:
R9 380
I5 6600k
Z170 pro gaming
You never really answered my question. With the graphics card removed, do you get a display from the integrated graphics on the motherboard?
-Wolf sends
There are lots of possible causes, but not getting a display from the integrated graphics when the discrete graphics card has been removed removes the graphics card and power supply as probably culprits.
Yes, if you do have bent pins, that could cause the system to fail to boot.
-Wolf sends
I just opened to check and CPU is intacta só it eeems but, motherboard hás 2 thingies that dont look like the others in the middle, they look like mini generators. http://postimg.org/image/a70ff8kkl/
I have built two PC that didn't boot at first.
For the first PC, the RAMs weren't inserted all the way, I removed them and inserted them all the way and it worked. Check to make sure that all your RAM sticks are really in there. Also make sure that the 8pin is plugged in and the 24 pin is also plugged in.
For the second PC, i had a dead CPU or MOBO, went back to Micro Center to have it exchanged and after reinstalling everything, it worked.
Hopefully you can get it to work without having to get it exchanged.
