[SOLVED] My pc has power but no activity
Dec 20, 2018
Hi.
I came down this morning to turn on my computer to find that it now isn't working.
I have replaced my PSU with a stronger one (to 500 from 400) but still the same.
All of my fans start and gpu fan. No LED on power button. Power button no longer will turn machine off when held.
Please help.
Many thanks
Are you sure the front panel connectors are properly installed. Also make sure that all cables are fully plugged in and in the correct place. First thing I do however is check my RAM, try to take it out and put it back in, and try putting a single stick in every slot possible.
Hi.
Thank you for the response. I have tried the connectors yes. I haven't tried the ram though so i will try that now.
But i have physically unllugged and replugged everything else.
