So I bought a new mb, cpu, and cooler about two weeks ago. I had some issues with my previous mb, they are listed here:
-My keyboard leds are not turning on always when I start my PC.
-Mb shows debug leds (All of them turn on separately).
-Internet connection is poor.
-Headset (Arctis 5) sound quality is crappy.
-PSU makes wheezing sound and it clicks when turning pc off.
-One vertical line in the middle of my screen moves to the left of the screen and leaves a blank space in the middle of the screen and the two pieces of the screen connect to each other.
When I installed my new mb and all of those other components, it showed up all those same problems. It works, but not correctly. Everything works fine after I reconnect my keyboard and headphones. As I listed above my psu is wheezing when I'm gaming and it makes a click when I turn off my pc. So I replaced my psu on its warranty with no result. I think the click comes because the power cuts out of every component at the same time. The wheezing becomes higher when the gpu needs more power. The only new problem which appeared when I installed the new mb was that my cpu shows up 12 cores and temperature is 90C on desktop. I have installed all the drivers correctly.
Specs:
MSI X470 Gaming Pro Carbon (new)
MSI GTX 1070Ti 8gb
HyperX Fury DDR4 16 Gb 2400MHz CL15
AMD Ryzen 2600X (new)
CoolerMaster Hyper 212 Black edition (new)
Corsair RM750x (new)
Seagate Barracuda 1Tb HDD
Samsung 970 EVO 500Gb M.2 SSD
In case you need these:
Acer Predator XB271HU
Steelseries Apex M800
Steelseries Rival 300
Steelseries Arctis 5
Specs:
MSI GTX 1070Ti 8gb
