I've recently bought a new RTX 2080 super amp edition and have been having a blast with the card, but things are getting a little hot! Here are some pics with FF XV running at 4k max settings to show you good comparisons of how hot it gets compared to when i take the side panel off my PC. Before those pictures ill post 2 pics of my setup first!
I have 2 fans on top of pc and 2 in front, both connected to tower properly so they spin at "fast" settings using the 2 switches near my power button and the fan on my cpu heat-sync is facing up, so blowing air upwards towards the case fans above which are also blowing air upward out of the case. Yes im also aware im missing 1 fan in the back of the PC case because it broke a while back BUT with that being said (and until my new one comes in) i can't imagine it will help my situation in the significant way that i need.
Now here are the comparison pics for temps, first up are the closed case temps, followed by open case, as you can see the difference is night and day. (Running FF XV at 4k max settings)
Closed case:
Then open case: (as you can see the temp drops are significant)
So basically im looking for suggestions as to what to do now while i wait on my new fan (which i can't imagine will fix my problem the way i like.
My big question is, is it alright to leave my pc open case for the time being? I understand it can cause dust build up but i have no problem de-dusting every now and then, im very thorough and my temps are so amazing with the case open at the moment. How dangerous is this? Will there be any damage caused by this? I feel there is more chance of damage leaving it closed and running at those temps but i dont know much about cooling! Here is also a full HW Monitor info pic as well with the case still open!
So last bit of info is that im running no overclocks (My zotac rtx 2080 super amp comes pre OC though) and i understand my AMD fx 8350 is a bottleneck at the moment as well (and i should note that the heat sync compound was applied this year, good t7 compound and applied carefully and before my 2080 arrived i extremely thoroughly cleaned all my fans and every inch of my tower so absolutely no dust anywhere at the moment). I also find my new 2080 runs around 85c both open/close cased on average playing this game. Seems a bit too warm! Turning fan curve up doesn't change anything just gets loud and temps still remain the same around 85c.
Anyways so besides general cooling tips my burning question is will it be alright if i just leave the side panel off my pc so that i can run games at temps that won't constantly make me nervous. Not going to lie im sorting of fishing for yes answers to this (at least for a month or 2 while i get better cooling ordered/figured out). But not afraid of cold hard truth, thanks in advance for any advice guys!
(update: well i guess my card is running around 75 with open case not 85, ill keep an eye on this and update here if it gets hot as 85 again, but when case closed its always running 85-87)
Update 2: thanks everyone for the help, the best advice ive seen so far is to get better more powerful fans on the top/front of my pc tower (as even when i place my hand over them they feel very weak) as well to of course get a rear fan. I want to clarify too that the cpu heat sync can't be rotated because of the mount doesn't match up properly with my motherboard when i rotate it 90 degrees and the fan above the cpu heat sync is in FACT blowing air upwards for those wondering. I tested with my hand if if you look the fan only clamps onto the heat sync in 1 direction only so you can't accidentally clamp it in the wrong direction, airflow is always going to be blowing out of the heat sync
Closed case:
