my pc shuts down at 50c(gpu).pls help
mohitmaximusroy
11
so my pc shuts down after temperature reaches 50c.
these are my specs
motherboard: Gigabyte GA-78LMT-S2PT
ram:8 GB
graphics: amd radeon r7 360
processor: AMd FX(tm) 4300 quad core
in games that need 8 gb ram pc shuts down in almost 5 minutes,and in less demanding games it shuts down after 20-30 min. there is no blue screen but its a black screen with weird looping sound,after which it shows no signal in my monitor but my cpu keeps running.
my idle temperature during browsing is gpu 39 and cpu at 20 but in videos gpu goes to 42 and cpu in 30.
pls help
That's for temperature ? As you probably noticed it's temperature margin to 62c when CPU is supposed to throttle down to save itself from overheating. It's built into CPU.
Vid0 gives you CPU core voltage. A drop in that value under load would indicate insufficient power delivered to CPU. Normally it should raise according to the load.
those were thermal margins.So do i change my psu?
