My PC won’t work properly
Nov 8, 2018
When I try to turn on my PC it will not get to the POST screen and I need to unplug it to turn it off. My keyboard and mouse do not light up, however my RGB CPU cooler does, as well as the lights on my motherboard. If someone could help me with this problem it would be appreciated. Thanks!
Specs:
ASUS TUF B360 PLUS GAMING
EVGA GeForce GTX 1060 6GB
8GB Patriot Viper 2x4 GB 2666mhz DDR4
EVGA 600BQ
Intel Core i3 8300
Cooler Master MA-G100M
Be sure to unplug it or turn the power supply off before you try and short the pins. You short the pins together by using something like the head of a screwdriver. If you don't have a anti-static band make sure you touch the power supply with the other hand to limit any static charge. Also you should pretty much always use a really good surge protector on electrical equipment that is worth more than 100$.
