My Philips tv with the following model:
Recently has some problems with the image with all channel except one. The image is not working but the audio is okay. Here is how the image appears:
The tv is a a bit old and it is using the following device to show the channels. (I don't know what is is)
The tv was okay until yesterday but the image is now not correctly displayed but the audio works. Note that the tv is connected directly with an antenna cable to the antenna without a decoder.
The tv works fine when i start the channels from the decoder, the problem is when i use the antenna cable directly from the tv without any decoder.
What can be the problem? If you need more info or you misunderstood something feel free to ask.
Thanks in advance
Thanks in advance
