My PSU 8-pin cable does not match the GPU 8-pin
You're not going to find them on Amazon. The PSU should already have the proper 6+2 pin or 8 pin GPU cables. If it doesn't then it can't properly power the GPU and should be tossed.
Seeing as you have an LC Power I can tell you its junk anyway, replacing it would be in your best interest.
